When I turn on the Air conditioner temp raises slowly?
05-13-2007, 02:03 PM
When I turn on the Air conditioner engine temp raises slowly to Hot? What could cause this?
05-13-2007, 02:20 PM
RE: When I turn on the Air conditioner temp raises slowly?
More then likely you have a coolant leak somewhere. The added load on the motor just causes it to overheat.
05-13-2007, 02:23 PM
somebody else had the same problem about a week ago and I think it was a head gasket but don't quote me on that!!!!
05-13-2007, 02:26 PM
The Rogue Mod
Generally it's normal for it to run a lil warmer. the condensor gets very hot and the fan is pulling that much more hot air across the radiator.
05-13-2007, 02:28 PM
Quote:
ORIGINAL: PRO50SC
Well it almost gets to the red line, and as soon as I cut the air off, it moves make to normal very slowly.
05-13-2007, 02:49 PM
It is normal to get alittle hotter when you turn the A/C, but going up to redline isn't. Check for coolant leak though, like Zach said!
05-13-2007, 03:09 PM
Well, i checked and i noticed some leakes around the coolant refil cap.. does this mean i need a new cap or sumthing?
05-13-2007, 03:52 PM
That would be a good place to start, maybe to be sure you could put a coolant pressure tester on it and check for leaks.
05-13-2007, 03:56 PM
ok thanks
05-14-2007, 12:18 AM
The Rogue Mod
I would look at the integrity of your fan clutch.
bjdutch2005
03-24-2017 03:38 AM
Pyrate Dave
09-10-2015 07:30 PM
Jose Corretjer
09-08-2015 06:32 AM
TimeLord101
09-04-2015 09:27 AM
