KOER Code help
Old May 13, 2007 | 10:50 PM
blybdas's Avatar
blybdas
Default KOER Code help
Need a little help. Until now, I have basically done all of my troubleshooting by ear and experience. Needless to say, I'm sure I've spent money in the past that could have been avoided by pulling the codes first. I pulled codes on one of my cars today (92 LX 5.0 vert). The car is running fine, but thought I'd pull them anyway since I had bought the scanner. I got two codes off of it (KOER), code 12 and code 18. My guess on the code 12 is I need to clean my idle bypass valve. No clue on the 18, though. Any ideas on either code?
Thanks.
Old May 13, 2007 | 11:04 PM
Joel5.0's Avatar
Joel5.0
Default RE: KOER Code help
18 - Spark Out (SPOUT) Circuit Open (R), Loss Of Ignition Diagnostic Module Input To PCM/SPOUT Circuit Grounded (M)
Did you run the car with the SPOUT disconnected?.......is it connected?....you should clear the codes, do a test drive (5-10 minutes) and recheck for KOEO codes and run a KOER self-test.
Old May 14, 2007 | 10:48 AM
blybdas's Avatar
blybdas
The only time I had the SPOUT out was when I have set the timing. My KOEO codes came back 11 (no problems). I'll clear the codes today then drive it and retest. Thanks.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
