max lift?
Old May 15, 2007 | 05:17 PM
d_och23's Avatar
d_och23
Default max lift?
whats the max lift on a camyou can go on stock heads before running into problems? what specs would i be looking for better 1/4?
AdderMk2's Avatar
AdderMk2
Banned
Default RE: max lift?
aftermarket cam on stock heads is a wasye of money
Old May 15, 2007 | 05:20 PM
d_och23's Avatar
d_och23
should i just keep the e303 i got now and just wait for the bigger cam until i aftermarket heads?
Old May 15, 2007 | 05:45 PM
90mustang5.8's Avatar
90mustang5.8
I ♥ Acer
always buy heads before the cam
Old May 15, 2007 | 09:39 PM
tinman's Avatar
tinman
There is a practical limit on how much lift you can have with ANY head.
There are limits to how much lift you can run due to ......
1) valve spring stacking.
2) how tall the valve guide is.
Old May 15, 2007 | 10:51 PM
ih8chevy's Avatar
ih8chevy
this is true. and the average lift can vary from motor to motor. u have to check ptv. what size cam u tryin to run?
ORIGINAL: 90mustang5.0
Old May 15, 2007 | 11:14 PM
vtecwho's Avatar
vtecwho
i dont see why you can get all of the power you need from the e303 cam. you can put down quite a bit of power with the stock cam and the RIGHT set up. bigger is not always better. you have to have the right combo
mtgldr
Feb 3, 2024 09:00 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
UrS4
Oct 3, 2015 06:23 AM
musnicki
Sep 23, 2015 07:11 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
