Submit Your Custom Cam Specs
in the name of science, research, and proving a point to myself and probabl other MF members - anyone with a custom ground cam please post your lift/duration/centerline so i can do some research.
Thanks!
*edit* i anticipate + .600 solid lift radical grinds used in straight up drag cars to be worth getting custom, but anything in the .500 - .600 hyd. street driver range to be a waste of money over choosing the best "out of the box" cam available for your application.
we'll know soon enough [8D]
Thanks!
If people actually post thier custom cam specs I think this will be a very informative thread. If possible you should also try to compare the difference in price to similar off the shelf cams and see if the power gain one might get from a custom cam is worth the extra price, especially for a mostly street driven car.
ORIGINAL: OnyxCobra
i think it could be quite informative. my goal is to see if for example, a person paid 2-3 times the price for a cam thats only a couple degrees apart, a few thousands different in lift, and similar centerlines. it should be noted that changes within those small tolerances will be unnoticable on the street.
ORIGINAL: OnyxCobra
How 'bout instead of arguing you just post your cam specs?
