HELP! coolant in motor
RE: HELP! coolant in motor
pull the upper intake off and remove the valve covers.... see if anything is bent or if you can remove any of the pushrods without unbolting anything.
if none of the pushrods come out, pull all 8 plugs, and crank the motor over... this will expel any fluid that is in the cylinders
logan409
09-26-2015 07:43 PM
