Idle Problems!!!!!!!
Old May 20, 2007 | 05:59 AM
nit4gudtime's Avatar
nit4gudtime
Default Idle Problems!!!!!!!
Ok Im having trouble with my idle. It idles fine when you first start the car but after it gets warmed up it wont idle. Starts surging till it dies. It wont idle properly till you let it completely cool down. Any ideas? I have set my iac. I take it to the drag strip and when i get to the traps and kick it neutral it just dies. Thanks for any help
Old May 20, 2007 | 06:01 AM
nit4gudtime
Default RE: Idle Problems!!!!!!!
Also even if i'm just letting it idle in gear it'll start surging and bucking. Thks
86 5.0L's Avatar
86 5.0L
have you cleaned it out with some carb cleaner? also I dont know if its the lack of sleep but maybe the clutch isnt disengaging properly
Old May 20, 2007 | 06:11 AM
nit4gudtime
I cleaned it out when i did my H/C/I swap. CLUTCH? lol
Old May 20, 2007 | 06:26 AM
86 5.0L's Avatar
86 5.0L
ORIGINAL: nit4gudtime
yeah, its the lack of sleep, it cant be the clutch [&:]
Old May 20, 2007 | 06:59 AM
BushDude's Avatar
BushDude
You didn't mention if this started right after the H/C/I or if it was laterbut did you check to make sure the EGR was reconnected.
Is CE on.
Did you check to make sure the vacuum lines to the upper intake were reconnected after the swap. I
s the PCV plugged in (another vacuum issue).
Just some places to start.
Old May 20, 2007 | 11:38 AM
hondhunter's Avatar
hondhunter
sounds like a vacum leak just check all the intake hoses for cracks , also u might need this plate to put in between your iac and the egr spacer, its to give more air when changin h/c/i its at www.mustangunlimited.com
Old May 20, 2007 | 11:46 AM
92GreyGT's Avatar
92GreyGT
My car has the same problem. What headers are you running? I had shorty headers and a Trick Flow stage 1 cam in this short block and all I had to do to get it to idle was drill a 1/4" hole in the throttle body blade and it fixed it. Then I put long tubes onand a bigger cam in and it will surge up and down until it dies no matter what you do. I put that plate that goes between the IAC and throttle body and that didn't help either. I can only get it to idle if it is set at 1100rpm.
Old May 20, 2007 | 03:12 PM
nit4gudtime
Oh yea it started immediatly after i did all the work to it.
I hooked a vaccumm gauge up to it and it showed 12 to 13 at idle which is bout 800 rpm's
Old May 20, 2007 | 03:13 PM
nit4gudtime
I'm running mac long tube headers
2007CalSpec
Dec 13, 2020 11:42 AM
2007StangV6
Jan 28, 2016 06:09 PM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
Emblazoned
Sep 3, 2015 10:45 PM
