Oil filter seepage why?
Old 05-21-2007, 02:29 PM
CCF5000
CCF5000's Avatar
Default Oil filter seepage why?
This is my problem i changed my oil the other day and did everything right put a pl30001 pure one filter on coated the gasket with oil and hand tightened it until the gasket contacts the base then another 3/4-1 turn start it up everything is fine no leaks but after driving around i checked it again and i feel on the filter and it feels a little wet i look at it and you can barely see it but it looks like oil seeps out the bottom part of the base for some reason should i just tighten the filter as tight as it will go? I've never had this problem on my other vehicle.
CCF5000 is offline
Old 05-21-2007, 02:31 PM
HACKGT350
HACKGT350's Avatar
Default RE: Oil filter seepage why?
is the old gasket still on there? that happens just tighten it more you should be fine
HACKGT350 is offline
Old 05-21-2007, 02:41 PM
CCF5000
CCF5000's Avatar
no i always check that after what happened to my friends dad it dumped oil everywhere because of double gaskets. I think ill just try to tighten it a little tighter. It's not like its dripping oil or anything but i like to have my vehicles perfect and you can feel a little residue on the bottom of the filter.
CCF5000 is offline
Old 05-21-2007, 03:58 PM
Scalihoo
Scalihoo's Avatar
yeah, my first thought was the old gasket was stuck to the flange, happened to me oce with my P Up truck , drove it around the block & she dumped 3 qts..
I bet you just need to tighten it a little more..
quick edit..maybe you forgot to oil the gasket before screwing the filter on ??
Scalihoo is offline
Old 05-21-2007, 04:32 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
did you put oil in the filter before you installed it?
2 kwik is offline
Old 05-21-2007, 06:22 PM
93 LX FiveO
93 LX FiveO's Avatar
when i switched to a pennzoil filter my car started doin this.
it never leaked before with a motorcraft and its not double gasket'd
93 LX FiveO is offline
Old 05-21-2007, 07:35 PM
my77stang
my77stang's Avatar
oh dont go blaming it on the oil LOL - maybe your just a ***** and cant tighten it up enough?
my77stang is offline
svfetter
10-05-2015 11:39 AM
wraith777
09-28-2015 10:49 AM
stangin1996gt
09-21-2015 11:01 AM
Demodulates
09-18-2015 11:14 AM
kevsgt
09-09-2015 06:20 AM
Quick Reply: Oil filter seepage why?
