converting carb nitrous sys to efi?
RE: converting carb nitrous sys to efi?
i figured the bottle was worth the hundred bucks alone, and i just found the zex kit minus bottle for 350 new, so if i cant peice it together i could buy that and still save a hundred bucks
yup just get a nozzle, and the jets for the hp you want to run... im in your shoes right now too, sept the guy is ASKING 199. so i figure i can give him 150 for it, and all ill need to buy is the wiring(which is why im not too too jumpin all over it) and jets, already have 2 nozzles off a buddies camaro
if you wanna spray dry, you need a nozzle, 3' of braided for the nozzle,nitrous reg, vac tee , micro switch and thats it
cost about $85-$100 probably for brand new
jetting for dry kits are :
42 in the jet 67 in the tee for 100 hp
67 in the nozzle and 42 in the tee for 150 hp (need to shim the reg for this)
42 nozzle 59 tee for 80
i'd run a wet kit since i think it comes with a fuel solenoid, i know next to nothinng about nitrous so i'm gonna have to find a friend to help
