jacking point
Old May 26, 2007 | 03:03 AM
83_stang's Avatar
83_stang
Default jacking point
Does anyone have any suggestion on a good jacking point? I don't want to mess up my underbody when I jack it up the last time I bent the ridge under the door because it was so soft.
Old May 26, 2007 | 03:05 AM
Does Not Exist's Avatar
Does Not Exist
Default RE: jacking point
put it under that huge piece of metal that runs the length of the car.[8D]
90mustang5.8's Avatar
90mustang5.8
I ♥ Acer
when i first read the title of the thread i was like wtf? [8D]
Old May 26, 2007 | 03:06 AM
Does Not Exist
lmao!
Old May 26, 2007 | 03:18 AM
Blckstng93's Avatar
Blckstng93
As mentioned theres a strip of steel just below the rocker panels. Each side has a 1" cutout for the scissor jack to fit in, thats why its there. If youre using a regular floor jack some use the rear torque boxes or under the front control arms, even the subframes. I prefer to use the k-member or the center section of the axle. if im just doing one side ill use the notches in the rockers with a scissor jack. Just dont ever use a jack on the floorpan itself.
Old May 26, 2007 | 03:27 AM
86 5.0L's Avatar
86 5.0L
depends which jack you use, if its the tiny stock jack, the ridge is suppose to line up and not bend
if its a floor jack theres the k member in the front the the torque boxes in the back
Old May 26, 2007 | 04:02 AM
93 LX FiveO's Avatar
93 LX FiveO
my pinch rail bent with the scissor jack
stupid unibody.
Old May 26, 2007 | 10:44 AM
OnyxCobra's Avatar
OnyxCobra
If you lift the car on the pinch weld right behind the front tire or right infront of the rear tire it shouldnt bend, it might in the middle though. Usually I either lift the whole front or the whole rear at a time though.
Old May 26, 2007 | 11:27 AM
capri debris's Avatar
capri debris
I do all my jacking inthe bedroom with the door locked. LOL.
Old May 26, 2007 | 11:39 AM
ALMOST STOCK's Avatar
ALMOST STOCK
jwog666
Dec 27, 2021 08:09 PM
flash_xx
Oct 16, 2015 07:23 AM
marc954
Sep 29, 2015 03:05 PM
Sep 25, 2015 09:06 AM
