Lean!!! UPDATED
#31
RE: Lean!!!
ORIGINAL: Joel5.0
You could also DIY with a paper clip and a 12-vdc test light (if the CEL doesn't work).
https://mustangforums.com/fb.asp?m=921609
#33
RE: Lean!!!
ORIGINAL: mattdel
hahaha! adder, i'm really diggin the rivet in the strut tower, nice touch
I kinda forgot what my engine bay looked like when it was all stock
#35
RE: Lean!!!
ORIGINAL: mattdel
you cant be serious, a dealership did that? jesus, another reason not to go to dealerships added to the list..
#36
RE: Lean!!!
So my lean codes came back today. I double checked the MAF voltage, tightened up all of my header bolts, checked my TPS, checked my ECT, checked my air intake temperature sensor, changed the fuel filter. They only thing that I really have left to do is clean my MAF once again (I didn't get to clean it very thoroughly the first time because I ran out of carb cleaner), test the 02's, check the collectors for leaks, and spray what few vacuum lines I can get to. I'm going to try and bring it into work tommorrow to have some of the other mechanics check it out because I'm almostall out of ideas. Is it possible that it's just time for a tune? Would a badMAP sensor cause this condition? How about the EGR?
stangin1996gt
09-21-2015 11:01 AM
