engine fan switch
Old Jun 3, 2007 | 11:27 PM
95BOSS302's Avatar
95BOSS302
Default engine fan switch
If the fan switch was out, then wouldn't that mean the engine fan would not come on at all
Old Jun 3, 2007 | 11:35 PM
95BOSS302's Avatar
95BOSS302
Default RE: engine fan switch
Also, what would cause the fan to come on when it first starts to heat up, then when it goes off, it doesen't come on again
Old Jun 4, 2007 | 04:06 AM
94IVGT's Avatar
94IVGT
it is controlled by the PCM which gets its info from the coolant sensor located in the front of your manifold on your passenger side. sensors get sluggish over time, its cheap throw a new one in there and if it doesnt fix it get yourself a wire diagram and run a 25amp FUSED toggle switch in there itll be alot cheaper than replacing the pcm.
djbigskrilla
Sep 20, 2022 01:04 AM
Scottyboy187
SVT Forums
Nov 20, 2015 02:57 PM
Scottyboy187
Nov 5, 2015 04:18 PM
MusicCity615
Sep 27, 2015 12:53 AM
HIS S-197
Aug 10, 2015 05:47 PM
