coolant temp sensor
Old Dec 31, 2004 | 05:31 PM
bobby's Avatar
bobby
Default coolant temp sensor
i picked up a new coolant temp sensor the other day, and i was wondering if i should put some tefolon tape aroudn the threads before i put it in, or just leave it go and put it in, just wondering, thanks a lot!
Old Dec 31, 2004 | 06:58 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: coolant temp sensor
use the tape!
Dbeck002's Avatar
Dbeck002
I ♥ Acer
always put teflon tape around the threads, and be careful not to wrap the sensor up with the tape. start the tape line a quarter inch above the beginning of the threads and that should be fine.
Old Dec 31, 2004 | 07:08 PM
nemethjames1's Avatar
nemethjames1
yup, is always a good thing to use... just make sure your not breaking a ground for anything, in thise case you wont be............. i had a prob with some sensor in a camaro, i bought it and still wouldnt work.... come to find out the tape was makin it not ground.. but i always use that stuff when needed
Old Jan 1, 2005 | 04:25 AM
bobby's Avatar
bobby
awsome, thanks for the replies, i will use it
Old Jan 1, 2005 | 01:34 PM
91hatchgt's Avatar
91hatchgt
Oh yes, the temp sensor.. It isn't that hard on our cars, I had to install a new one on a 1991 Camaro RS, what a pain in the ****...
Old Jan 1, 2005 | 05:05 PM
86HOGT's Avatar
86HOGT
Yeah use the tape if you don't want the sensor to work. t uses pipe threads which seal themselves because they're tapered. IF you use the tape, then the sensor won't ground and won't read properly...or is that on temp switches...shoot...I don't know.
Old Jan 1, 2005 | 05:15 PM
nemethjames1
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
