GTS Missing
#53
RE: GTS Missing
lol so what can i use to check my ground? a dummy light, and from where can i get a hot source to check it with? will there be one close by, like in the harness? and if its the fusible link, just cut it out and replace it with a new one?
#54
RE: GTS Missing
yup pretty much.
as far as testing, use a test light. in the clip on the test light, run a wire to the positive side of the battery. then just touch the ground wire. if the ground is any good, the light will turn on.
#56
RE: GTS Missing
alright thanks guys. i can understand that now. i just hope it works. im tired of fooling with it. like i said before i hate electronics because to me it seems that there are just so many places somethin can go wrong, but if theres another time it does im asking you two
#59
RE: GTS Missing
well figured it out finally had time to mess with it and it only took me like a minute! the inertia switch plug was barely plugged in! omg i couldnt believe that! but anyways id like to thank all the guys who posted on this topic for their help thanks again
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
