coolant
Old Jun 10, 2007 | 01:41 AM
crocop's Avatar
crocop
Default coolant
my 88 for some reason loves to drink engine coolant. i top it of fully run the car for a bit like take it for a drive wat ever, check the coolant fill box and ittll be next to empty. i opened the cap on the rad and it seems to be fine its nice and full. is this mean im just low and i have to add untill i fill the system or something. another thing is that when ever i start my car i get a nice load of water coming out from the exhaust and its slightly brown. i know a little is ok but if i get alot does it mean i might be leaing coolant?
Old Jun 10, 2007 | 02:14 AM
ovalracer98's Avatar
ovalracer98
Default RE: coolant
most likely a head gasket if you are not leaking coolant. Do a cooling system pressure test to find any possible leaks. If no leaks externally,then pressurize each cylinder to find a presure leak into the cooling system which will indicate a failed head gasket. The coolant has to be going somewhere..lol
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
Vrooom
Feb 21, 2016 05:25 PM
wraith777
Sep 28, 2015 10:49 AM
MusicCity615
Sep 12, 2015 07:05 AM
