30# injectors with AFPR
im trying to find what fuel pressure I should be using with my 347. it smells like its running rich but I may be wrong. Anyone got a suggestion? overall timing with spout on should be what?
RE: 30# injectors with AFPR
Pull the spout and set the timing to 10-12*, then put the spout back in.
The fuel pressure should be set to the factory pressure... 38-40psi.
If you have to stray more than a couple of psi from that, then something is wrong.
Is the MAF cal'd for the 30's???
jason
jason
Just checked online and according to UPS.com, my Kirban AFPR is sitting in my porch as wel speak. Can't wait to get outt work and go slap that on. Then I'll have to go on a long drive to datalog some numbers and see how it's holding up.
ORIGINAL: samseed101
