Installing NX tonite ne suggestions
i read though the directions... doesnt seem to bad... but i am goin to hind it, mount it were the smog pump used to be.... and drill the jet hole towards the underside of the CAI....and use that black stuff over my stainless lines so they dont stick out... that way my engine bay will look stock apart from a nice paint job... i was wondering if ne have ne input... big things to watch out for.... im not goin to hook it up to power or to the tank(thats empty) just run all the lines and what not and get everything mounted and that way the shop can check it then fill the tank hook it up and hook up the power to the solineds and tune it... sometime next week hopefully... newayz... just suggestions to make this install some
RE: Installing NX tonite ne suggestions
ORIGINAL: stangman94
did you finish your hci?
what kinda shot?
what kinda shot?
ORIGINAL: aode06
YEAH dont hit it in FIRST.
Only use in HIGH rpms, so the engine can suck it through.
Dont have your timing past 10* ,
no, it should have a soleniod that you wire which senses when the car is at WOT, there shouldn't be any physical switch near the pedal. It will have a light on the box which lets you know when it is armed. Then most people wire a toggle switch so that they can drive the car N/A at WOT without the nitrous. At least that's how I did it with my ZEX kit on my 89.
How much are you spraying
