Rocker arms
01-06-2005, 08:10 PM
Rocker arms
I just bought some 1.7 rocker arms. Should I go ahead and replace the springs and retainers while installing the new rocker arms?
01-06-2005, 08:13 PM
RE: Rocker arms
springs yes retainers if you want.
RE: Rocker arms
well if your still stock cam..no if you stepped up with a cam then yes simple as that
01-06-2005, 11:55 PM
RE: Rocker arms
if alot of miles on springs, then yeah springs, not to easy i dont think
01-07-2005, 12:28 AM
RE: Rocker arms
Quote:
ORIGINAL: nemethjames1
yea... I don't think you can change the springs with the heads in the car can you?
01-07-2005, 12:33 AM
RE: Rocker arms
yes you can
01-07-2005, 12:36 AM
RE: Rocker arms
yes you can, you need to compress the cylinder, so that the valve does not fall down.... its a little tricky, but is do-able
01-07-2005, 12:44 AM
RE: Rocker arms
coo... is there some type of special tool to compress the spring?.. I only know of the c clamp type...
Sixer4Life
10-12-2015 04:26 AM
UrS4
10-03-2015 06:23 AM
UrS4
09-30-2015 10:13 AM
uedlose
09-30-2015 08:01 AM
Sixer4Life
09-28-2015 07:05 AM
