this a good h/c/i combo?
RE: this a good h/c/i combo?
dude i got a comp cam XE270HR on my 331, there is no driveability problems. .512 lift, 110degree untake centerline, lobe seperation 114degrees. i wish i went with some more lift now, but it should do me good.
ORIGINAL: 90mustang5.8
cant go any bigger than that for cam unless i want no street driving. what do u think? 185's? or should i risk the 205's?
how bout this cam? http://store.summitracing.com/partde...p;autoview=skuwould it be streetable also?
Have you taken into account the need of linked lifters to run the TFS HR (or any other brand) camshafts in your '72 351w non-roller block?.........FYI.....the spider-dog bones retrofit kit would only allow a small base circle HR cam[:'(] to be used, making those cam "alternatives" unreliable.
so lets say i went TF stage 2, with trickflow ported 185cc heads and edelbrock Jr. victor intake. i would get 11.5's?
suspension
-3.55 gears
-90/10 and 50/50 lakewood struts
-UPR upper and lower adj. control arms
-sub frame connectors
-4 cylinder springs
-welded boxes
-air bags, 5lbs driver, 12lbs passenger
weight removed
-no front sway bar
-no a/c or heater
-no spare tire/ jack
tires
255/60/15 mickey thompson drag radials (might consider 235/60/15's becasue the bigger tire may kill my time) on a centerline 15x8 rim
still have to get a 3500 stall torque convertor.
to be honest i can drive i just turned 16 a while ago, but lets say i am a good driver, times would be. with that suspenison set up and a stock 351w i should run really low 13's
-3.55 gears
-4 cylinder springs
-welded boxes
weight removed
-no front sway bar
-no a/c or heater
tires
