quick question?
Old Jun 18, 2007 | 10:10 PM
URLACHER54's Avatar
URLACHER54
Default quick question?
i wa underneath my 88 GT and noticed that i have a pipe that goes from the stock H-Pipe up toward the motor, i didnt get a chance to go and look under the hood, but is this the EGR tube if so when i change to put on my BBK shorties, BBK hi flow X pipe and cat back system there is no way to hhok this back up to new system correct. and what do i do?
Old Jun 18, 2007 | 10:14 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
Default RE: quick question?
its not the egr it comes from the smod pump it injects fresh air to help the unburn gasses burn you can braze/weld it to the new pipe or remove it esp if you dont ahve a smog pump
Old Jun 18, 2007 | 10:50 PM
URLACHER54's Avatar
URLACHER54
will it effect the check engine light if i remaove the smog pump or fail me on Maryland emissions
Old Jun 18, 2007 | 11:21 PM
URLACHER54's Avatar
URLACHER54
anybody eliminated their smog pump what are the effects of this?
Old Jun 18, 2007 | 11:24 PM
rcdblink716's Avatar
rcdblink716
it might send a catalytic efficiency code and yes u should fail emissions no matter what. If you have any emission systems removed they are supposed to fail u. I haven't actually done this myself though so it might not trip a code
Old Jun 18, 2007 | 11:27 PM
Joel5.0's Avatar
Joel5.0
It will depend on the requirements in Maryland.....if they do a visual and don't see the smog equipment installed...will it pass?....if they don't do a visual, you shouldn't have problems as long as the system (EEC-IV) is failure code free (with the exception of the smog related KOER codes)....and no....its elimination will not cause the CEL to illuminate.
Old Jun 18, 2007 | 11:30 PM
Joel5.0's Avatar
Joel5.0
ORIGINAL: rcdblink716
It's not OBD-II.......
Old Jun 18, 2007 | 11:43 PM
willett2007's Avatar
willett2007
i live in pa.my smog was removed years ago.i have no problems with inspection or check engine lights.you also free up power by removing it.
Old Jun 18, 2007 | 11:45 PM
945LSTANG's Avatar
945LSTANG
ORIGINAL: willett2007
not much of anything.
Old Jun 18, 2007 | 11:50 PM
willett2007
true but it does take away an acess of your serp system.
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
