is there a diffrence between these?
Old Jun 18, 2007 | 10:25 PM
pro tint's Avatar
pro tint
Default is there a diffrence between these?
a H.O and a non H.O distributor like form a "mustang" to a "towncar"
Old Jun 18, 2007 | 10:54 PM
Joel5.0's Avatar
Joel5.0
Default RE: is there a diffrence between these?
If the non HO is not a roller cam (roller cams also came with the 1542.... firing order BTW).....the ditributor gear would have to be replaced to a steel gear.
Old Jun 18, 2007 | 10:59 PM
pro tint's Avatar
pro tint
well i pulled mine from a junk yard and it came out of an 88 towncar with the non H.O motor (pretty sure it was roller) would that cause any issues if used in a 1990 stang???
Old Jun 18, 2007 | 11:07 PM
AdderMk2's Avatar
AdderMk2
Banned
as long as you are using it on a non HO cam you will be all set, if running an HO cam, you need to change the gear
Old Jun 18, 2007 | 11:14 PM
pro tint's Avatar
pro tint
what will it run like if i use a non H.O distributo gear with a H.O cam?
Joel5.0's Avatar
Joel5.0
Yup....'88 TownCar was a roller cam......you can use it as is.....it already has the steel gear.
Old Jun 18, 2007 | 11:19 PM
Joel5.0's Avatar
Joel5.0
ORIGINAL: pro tint
It's not a matter of HO or non-HO cam.....it's a matter of material compatibility. The roller cams (HO or non-HO) require the steel gear, if you use a non-roller cam gear (iron) it will go snafu in the engine.....break, fu-cam or engine.
moyam01
Jan 24, 2006 11:57 AM
Speedeamon
Dec 23, 2005 03:47 PM
gotboost
26
Nov 23, 2005 07:35 PM
Dan89lx
Jan 6, 2005 08:21 PM
countrycannon8
May 1, 2004 12:02 PM
