just did a compression check!
#33
RE: just did a compression check!
nope it was in it! if its the cam im going to be sooo pissed. I talked to the lead tech over at AMP and he told me it was fine that I must have done something wrong.
#35
well got at least 150 compression in all eright cylinders, what i did was had tighten all the roller rockers and it worked. i guess im going to have to use some spacers (super thin)to bum the rollers up a hair and try to even the compression out on all the cylinders because a couple of them are up in the 170 range and the lowest is 149. the only problem i noticed is that it is having some back firing
uberstang1
09-20-2015 06:42 PM
TfcCDR
09-14-2015 12:08 PM
