still overheating
ok i just put in a mr gasket 180 stat and i new 2 core aluminum radaitor with a bid *** electric fan and new hoses. im still over heating all the way to the L in NORMAL. if i use the heat it stays barely under.
what else could i be missing???
ORIGINAL: GT350
Thermostat in backwards, blown head gasket, water pump, take your pick they are the only things left.
didnt have to replace the radiator tho
With the radiator cap removed, let the engine idle till warm, then put a metal thermometer in the water in the radiator to get an acurate temp. I never trust factory gauges without numbers.
Watch for the water to start moving in the radiator when the thermostat opens, this will prove that the thermostat is opening and the pump is pumping.
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
