Found a vacuum leak. Got a question.
I just got my digital code reader from Amazon today and put it to use. I got a code 91, System always lean. I also found the vacuum line to the A/C broken. Is it possible for that small of a leak to cause a lean condition?
RE: Found a vacuum leak. Got a question.
ORIGINAL: Pony 5.0
I have the same code and have been told by several people on this site way smarter than me that code 91 probably means you 02 sensors are bad. Have you run both the KOEO and KOER tests with the 91 code showing?
I only ran the KOEO to pull codes since I have been getting an intermittent CEL. I just reset the computer and blocked off the vacuum line. I'll see tomrrow how my pony gallops and run the KOER. Thanks for your help.
I know for a fact the its the O2 sensor because i just pulled my codes today and i got that code and another O2 sensor code. Looks like when i did my TKO swap i dented the side of my O2 sensor in so I know thats the cause
ORIGINAL: HACKGT350
yup any small lean can pull a code. try running the car and taking carb cleaner spray it around the engine on all the vacuum lines and along the gaskets of the upper and lower intake, if the idle goes weird you have found your leak
ORIGINAL: Pony 5.0
KingRando
10-02-2015 08:06 AM
