Hello all you 5.0 guys
Old 06-26-2007, 01:13 AM
lynwood78
lynwood78's Avatar
Default Hello all you 5.0 guys
I recently purchased a Black 89 Hatchback. I always wanted a Fox Body Mustang. Everything is stock. What are some minor mods I can do for a begginer? Intake, exhaust,etc or should I just leave it like it is. Exhaust is already loud than it is but I wouldn't mind adding a little more ponies toi my car. I'm not planning on building up the motor or anything. I'm just gonna use it for a daily driver. Thanks.
lynwood78 is offline
Old 06-26-2007, 01:15 AM
945LSTANG
945LSTANG's Avatar
Default RE: Hello all you 5.0 guys
gears, exhaust, and tires
945LSTANG is offline
Old 06-26-2007, 01:25 AM
1995mustang818
1995mustang818's Avatar
and some upper and lower control arms
1995mustang818 is offline
Old 06-26-2007, 01:32 AM
nacanitihs
nacanitihs's Avatar
well first what do you have for exhaust? also is the air silencer in the fender removed yet that will free up some air flow and a few ponies.. just do a few bolt ons like a bigger TB (65mm or 70mm) and a bigger MAF 73mm and some gears (3.55 or 3.73) to start and you prob will have what you are looking for
also automatic or 5-spd??
nacanitihs is offline
Old 06-26-2007, 01:52 AM
1989BluePony
1989BluePony's Avatar
I was in ur same position a few months back, a unmodded 1989 LX 5.0. I recently went with a magnaflow cat back and a h-pipe. I felt a difference in power and it sounds great. Also i agree with the others do gears! and headers
1989BluePony is offline
Old 06-26-2007, 02:07 AM
Blckstng93
Blckstng93's Avatar
Doublecross sub connectors, weld up the torque boxes in the rear, gears (3.55 or 3.73), slotted front rotors, and complete tuneup.
Automatic? new fluid and a shift kit
5 speed? replace the shifter atleast
Whats your exhaust like? It should be atleast 2 1/2" starting at the H-pipe.
Blckstng93 is offline
Old 06-26-2007, 11:16 PM
lynwood78
lynwood78's Avatar
Thanks for the responses. The car is a auto. The car is 2 1/2 starting at the H-pipe. What motor oil is recommended also?
Old 06-26-2007, 11:28 PM
jthorn9
The Godfather
jthorn9's Avatar
SAE 10W-30
Here are a few great begginer mods.
Get a K&N filter, remove the air silencer, use some silicon adhesive that can be removed if needed, apply to the back of the filter, and drop it in, basically does the same as a CAI.
Gears are always a good idea. I like 3.55s, but others like to go higher, so that one is up to you.
Upper/Lower control arms, these will really help the car handle better in both regular driving, and off the line.
jthorn9 is offline
Old 06-27-2007, 12:19 AM
stang8689
stang8689's Avatar
3.73 gears for most go, flowmasters or some other cat-back for some real sound
stang8689 is offline
Old 06-27-2007, 12:46 AM
WhiteWindsor
WhiteWindsor's Avatar
3:73 gears.throttle body,MA. Take out the filter box and add K&N cone filter,with these couple of things you can bump your timing. Underdrive pulleys will free up a couple horsepower as well. Correction, with an auto get 4:10 gears
https://mustangforums.com/upfiles/70...86D36A0B18.jpg
[IMG]local://upfiles/70384/6FAC083D077142589A64579841BCE9F1.jpg[/IMG]
[IMG]local://upfiles/70384/C5BA03AFB5ED44CEA89A979ABDF4B569.jpg[/IMG]
WhiteWindsor is offline
Quick Reply: Hello all you 5.0 guys
