doesnt seem to get fuel
I've just got new motor in, 347 replaced 19 inj. with 24s, 76 mas calibrated for 24s 70mm TB.
tried to start many times, but doesnt want to fire, checked timming 2 times, pulled plug wire off, it is firing,
pulled plug out, don't see or smell fuel, schrader valve has fuel to it, pump is running when to key on.
Any help??
Any help??
RE: doesnt seem to get fuel
all you need to check to see if the injectors are pulsing is a noid light it plugs into the harness and flashes if the injectors are getting the signal to fire. no way around checking fuel pressure accuracy without a gauge !!! autozone sells them for 35.00
mrappe
09-26-2015 10:16 AM
