fuel injection to a carb set-up
i got a 88mustang gt and its fuel injected i got the gt-40 upper and lower intake but my buddy said he would trade me a 289 torker low pro single plain intake with a 600cfm holly carb that hes gonna put a trick kit in, he is also going to install the setup on my car and i was just wondering what u guys all thought about this, i mean i like fuel injection but i want to go fast for cheap and the car is only drivin like 3days a week if that
RE: fuel injection to a carb set-up
You'll be slower with the Torker. If you NEED a single plane manifold(which I doubt you do since I'm assuming you don't have a 7,500rpm screamer) then use a Vic. Jr. since the Torker is an atempt at a single plane manifold in a dual plane rpm range.....it failed. An Edelbrock or Weiand low rise dual plane, or a medium rise dual plane if you have a pretty thumpy street cam(powerup to 6,500rpm)and some gear in the rear will do you much better
the torquer was good back in the day, now its been proven over and over again that the performer rpm makes more torque and even makes 2-3 hp up top over the torquer. if you are wanting to move to carb i would buy a different manafold. he is only offering about $325 worth of parts new.
going carb is a good way to usually pick up 20-25 hp over a stock efi setup, you have a fairly decient intake so gains would be minimal right now.
i would stay efi untill you find some decient heads, than move to carb. if you stayed with efi with good heads you would dump lots of $$ into a bigger maf, tb, injectors, fuel pump, etc.
i would rather build a carb motor vs an efi motor.
jwog666
12-27-2021 08:09 PM
mrappe
09-26-2015 10:16 AM
