nitrous runs tn... somethings not right...
RE: nitrous runs tn... somethings not right...
Any idea what your A/F ratio is when spraying? I wonder if you're running too rich or something. How's the bottle pressure looking? I know that when you topped it off, it probably got cold as hell and that could cause some pressure issues.
I don't remember but do you have a purge solenoid? It may help get you off hte line if you can clear the lines.
Are you running on regularradials or cheaters, slicks? Your car should run alot better then that. My buddy went 12.15 through the cats with a crank pulley and flow masters and slicks WITH 3.08's. What all do you have done to your car?
mickey thompson street drag radials... 235/60/15
4cyl springs up front
strange 10 way struts up front
o/r h pipe
dumped flows
100 shot(wet)
n/a-14.2 consistantly
spray-13.8 best
o/r h pipe
dumped flows
100 shot(wet)
spray-13.8 best
ORIGINAL: FullAuto
Did you run it N/A to compare how much the nitrous was helping you under those conditions? How did your mph improve?
and mph went from 98 to 101
