nitrous runs tn... somethings not right...
#51
RE: nitrous runs tn... somethings not right...
You need a bottle warmer no matter what the temp is outside or if you just got it filled or whatever. I would say having a bottle warmer would make a huge difference if you don't have one already.
-Jeff
-Jeff
#52
i do have colder plugs... i feather it from 2500 and it works out.... i dont dump it at all... i have stock rear suspension, so i dont think itll hook a higher launch, but im up for new ideas...
and well, no more nitrous runs for a week or two... i just blew 2nd gear
#53
ok,adding gears will only create a traction issue without suspension mods....most people here don't get this....I would try the manual shot to see if times improve this will tell you what you need to do in your driving and how you must set up your system
#54
if anything ill just bypass the window switch to see if thats the issue... but like i said, its gonna be alil while, blew 2nd gear.... yea after i fix the trans im orderin control arms, bags for the springs, rims, and some other little ****, then gears in the fall
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
Kenta08
09-02-2015 10:33 AM
