Rust how to fix?
Old Jul 8, 2007 | 12:13 AM
86_GT_Mustang's Avatar
86_GT_Mustang
Default Rust how to fix?
How would i go to fix this?
Old Jul 8, 2007 | 01:29 AM
86_GT_Mustang
Default RE: Rust how to fix?
bump
Old Jul 8, 2007 | 01:39 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
call 5.0 resto.com and see if they have a patch pannel. you'll need to cut the inside out to. and after that grinde about 3 inches around the spot so you can tach weld the new panel in place. or cut a good one out of a used car. they make a flange tool thet fits in a air hammer that'll make/roll a lip on the edge so all you have to do is set the panel in place and tach weld with a mig welder. I cut the whole back off a 68 cougar and welded a new one on for a customer of mine and it worked great!! I love this kind of work if I were close I 'd love to help.
Old Jul 8, 2007 | 01:40 AM
PJB's Avatar
PJB
Make a new piece out of sheetmetal and weld it on.
It looks like you will also need to make an inner piece as well. Thats going to be harder to do because of the location. You might need to remove the gas tank to weld the inner piece in.
My car rotted out in the same spot but only the outer layer of metal was affected.
Old Jul 8, 2007 | 01:42 AM
mjr46's Avatar
mjr46
P.S you'll need to remove the rear bumper cover also to work with this and if your welding maybe a good Idea to take the gas tank out too becauseyou'll be right beside it and left tail pipe to easier work with the area
89 fox's Avatar
89 fox
ORIGINAL: mjr46
+1 if ya don't have a welder....a glue called panel bond works real well also! make sure to prep the surface real good first either way!
Old Jul 8, 2007 | 01:48 AM
86_GT_Mustang
thanks for the info guys
Old Jul 8, 2007 | 01:49 AM
mjr46's Avatar
mjr46
Yeah 89 I saw that stuff on the show TRUCKS they patched a panel on a project called s-10k looked like IT WORKED WELL TO AND THEY EVEN USED A ROLL ON PRIMMER!! damn caps button again!!!
Old Jul 8, 2007 | 01:51 AM
89 fox's Avatar
89 fox
ORIGINAL: mjr46
i saw that one! i used is years ago to glue a wide body kit on an eclipse when i was doin body work
Old Jul 8, 2007 | 02:35 AM
remicks's Avatar
remicks
After you're done with welding or whatever option you choose make sure you slap alot of POR-15 on it and pretty much any other exposed metal you can find, that stuff works miracles. Also you can ask the classic forum guys for help too, they have tons of rust experience.
jerrytubes
Oct 23, 2015 12:11 PM
b8checker
Oct 8, 2015 12:55 PM
ChampInSD
Oct 2, 2015 04:55 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
b8checker
Sep 30, 2015 07:11 AM
