electrical problem need help!!!!!
my passenger side door power switches wont lock or roll window up or down, i can lock and unlock the passenger side from the drivers side. but cant make the window roll up or down fromdrivers side..... i dont get it so i know the door lock acctuator works but still not sure if the window motor does... should i try to replace both the swiches on the passenger side to see if its the switches or not need help
RE: electrical problem need help!!!!!
loose connection somewhere in the door is my guess, corrosion maybe. My pass side window wont open sometimes, I have to open the pass side door or even move the car to get it to work.
ALL THE SWITCHES DO IS CONTROL THE GROUND SIDE OF THE CIRCUIT since the master switch operates the passanger side door lock (mine did this too) I'd replace the door lock switch on that side. as for the power window remove the door panel and put a test light down on the motor power side and operate the switch if it won't light the problem is further up in the system as cheap as the switches are and ease to replace try that first if you don't have test equipment !!! If you say the switch is fine??? DID YOU TEST IT with an ohmmeter if it's fine place one of the leads on one contact and one lead on the other when you move the switch the ohmmeter should read continuity. DID YOU DO THAT TO TEST BOTH SWITCHES???
uberstang1
09-20-2015 06:42 PM
ccdguy
09-19-2015 05:20 PM
TfcCDR
09-14-2015 12:08 PM
