pinion shaft retainer bolt?
Old 07-12-2007, 08:12 PM
kweb288
kweb288's Avatar
Default pinion shaft retainer bolt?
hey guy's ive been bussy all day taking the 8.8 out of my fox and ran into a road block, the pinion shaft retaining bolt is frozen and i cant get it to turn, any ideas of how to get it out, im replacing EVERYTHING so if all else fails is there a way to cut it out, (looking for other ways first though that is just a last resort) thanks for the help
kweb288 is offline
Old 07-12-2007, 08:22 PM
kweb288
kweb288's Avatar
Default RE: pinion shaft retainer bolt?
never mind lol, just put a wrench on it and beat the $h!^ out of it with a 9 pound and it came loose after a few smacks
kweb288 is offline
Old 07-12-2007, 08:52 PM
67mustang302
67mustang302's Avatar
I hope you have a big enough torque wrench to put it back on. I dunno how the 8.8's are but on my 8" the pinion gear locknut has to be tightened to 170ft-lbs or more to get the appropriate amount of rotating torque on the pinion bearing preload
67mustang302 is offline
Old 07-12-2007, 08:59 PM
Boss_Hotrod
Boss_Hotrod's Avatar
He's talking about the little 5/16" bolt that holds the pinion shaft in the carrier. It should've just popped loose. Id deffiantley get a new one if you plan on rebuilding the traclok.
Boss_Hotrod is offline
Old 07-12-2007, 09:01 PM
Mustangkiler
Mustangkiler's Avatar
yup, i used a breaker bar and my leg, when u tighten it up, just tighten it till u get the front and back ply out of it and u will be fine but you will have to shim it up first before the final assembly.
Mustangkiler is offline
Old 07-12-2007, 09:48 PM
67mustang302
Oh, my bad, mine has a roll pin. I figured since it took so much force he was talking about the pinion gear nut.
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
bradleyb
11-27-2015 07:50 PM
KingRando
10-02-2015 08:06 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: pinion shaft retainer bolt?
