car wont hardly run????
I have a 93 gt with a few mods...cobra intake, recal maf, 24 lb inj, u/d pulleys,bbk e/l/s, off road x, flows,and here is my prob. took my son for a drive the other day went into a store come out and it starts for 5 seconds and dies...wont restart. so i call afriend to pull start me which works but the car is running so rich that it will only run if you keep it reved up ... i took it directly to my shop and parked it havent had much time to mess with it... i did put a new fuel pressure regulator on it and that didnt help... anyone had this prob or got any ideas???
RE: car wont hardly run????
it will start but wont idle and doesnt run for crap...its running way rich ... havent had a lot of time to check really anything yet ... i also noticed that the fuel pump keeps running with the key in the on position before starting...fuel pressure is dead on
The pump running w/ the koeo is not causing your problem. That could be the relay sticking though.
I would look for a vacuum leak, check your ECT sensor and your ignition module could be acting up as well.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
