installing equal length headers
Old 07-16-2007, 11:11 PM
MEM 302 5.0L
MEM 302 5.0L's Avatar
Default installing equal length headers
im installing some new hedman equal length shorties,
and i was wondering if anyone had any helpful tips,
the engine is in the car.
MEM 302 5.0L is offline
Old 07-16-2007, 11:26 PM
86 5.0L
86 5.0L's Avatar
Default RE: installing equal length headers
jack it up a bit, and use a piece of wood inbetween the jack and motor
86 5.0L is offline
Old 07-16-2007, 11:28 PM
MEM 302 5.0L
I DO need to unbolt the motor mounts right?
Old 07-16-2007, 11:38 PM
91blackmustanggt
91blackmustanggt's Avatar
Youwill need to takeoff your air intake, mass air meter,smog plumbing to get at the pasenger side. Undo your motor mounts and lift your engine an inch or so and you can use apry barunder your motor mounts to hold the engine away from the side you are working on to get enough room to put the header in place. An extra set of hands helps!Youmay need to figure out a way to make your dipstick work. You shouldn't have to undo the steering shaft like the directions might say orInever had to with my BBK's.
91blackmustanggt is offline
86 5.0L
86 5.0L's Avatar
lol, yeah that would help
86 5.0L is offline
Old 07-16-2007, 11:41 PM
MEM 302 5.0L
I already have the passenger side in, i just need to get smaller header bolts, the original bolts rub the tubing. I already have a dent in the the drive side header to clear the steering equipment.
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: installing equal length headers
