Torque specs
I need to know the torque specs for all the bolts to the engine. I'm starting on putting the engine back together tomorrow when I get the cylinder hone & ring compressor.
maybe you dont have what it takes..LOL.. just reading the sig you have.. you could also go buy a hanes manual..
ORIGINAL: FoxGT
ORIGINAL: mstng675l
ORIGINAL: FoxGT
I went w/ Haynes...Chilton has pretty much the same specs, too. I don't know the specs off-hand, but i know the cylinder head bolts (or studs) should be tightened to 65 the first time (working from the center=>out) and 70 the 2nd time around. If you still need the others let me know and i'll post them.
ORIGINAL: bobby
good link! saved that one, question tho............... do those torque specs for the rockers apply to roller rockers?? i dont think so , but wanna make sure, thanks!
Roller rockers are adjustable, therefore custom tuning applies. Also, I wouldnt recomend using roller rockers without screw in studs and guideplates. theres quite a bit or machine work involved there.
LivingInThePast
Sep 16, 2015 12:20 PM
