Need help! Gas licking
Where can I get a whole new system for my car? I was just at the gas station right now and when I finished filling her up I've notice there was a gas lick so i had to push my car out of there. Then i started her up and took her home and as I was about to park in the driveway I've seen a gas trail following me. I need to replace this as soon as possible. Can I take it to the dealer and have them replace it for me??
RE: Need help! Gas licking
Be careful! Licking gas can be hazardous to your health! plus it don't taste good either!
Now, if it is a leak you have follow PJB's suggestion! Get under and find out where the leak is and just replace what is broke!
There is a rubber gasket there (grommet actually. its really big/thick), I had to replace mine. Advance didnt sell it, I had to get it form a ford dealer (or you can order it from here http://www.latemodelrestoration.com/...1&comp=LRS). Fairly easy to replace. Takes a little bit of time. Could be easier if you have a friend to help you. A little trick is to drop the whole tank and maneuver the tank into the neck than the neck into the tank (i know some of you may disagree, but I did it that way and was much easier). Just dont put more than 6 gallons in at all times till you replace it or else itll spill out the side when you take a left turn.
Matt's 95 Stang
10-05-2015 07:16 AM
