what pushrods and rr
Old 07-19-2007, 10:58 AM
ant0045
ant0045's Avatar
Default what pushrods and rr
what will i need for gt40p heads??? rr and pushrods
ant0045 is offline
Old 07-19-2007, 11:36 AM
my77stang
my77stang's Avatar
Default RE: what pushrods and rr
normal 78-newer stamped steel rocker arms and standard length pushrods will work if you have a cam thats stock, or with a stock sized base circle. you can use a stud conversion kit if you want to run normal roller rockers, or you can get pedestal style rollers that bolt directly onto the heads. personally, i recommend the stud conversion kit so you can reuse your rockers later if you get aftermarket heads
my77stang is offline
Old 07-19-2007, 12:12 PM
ant0045
ant0045's Avatar
forgot to say im gunna be using an e-cam
ant0045 is offline
Old 07-19-2007, 12:25 PM
my77stang
my77stang's Avatar
get the rocker arm stud conversion kit, im too lazy to look it up in summit but its less than 100 bucks, then grab some roller rockers and some standard length hardened pushrods.
btw, you know you need stiffer springs with that cam right?
Old 07-19-2007, 12:31 PM
ant0045
ant0045's Avatar
getting the heads from tristate cylinder heads, they told me that the head will be fine with that cam, thanks though[/align]
ant0045 is offline
Old 07-19-2007, 02:12 PM
ZachW04Stang
ZachW04Stang's Avatar
Your gonna have to get a pushrod length checker to know what pushrods you need. I needed ones that were .020 shorter then stock with my p heads.
I couldn't find a pushrod length checker that came shorter then 7.5" long and just made my own out of 2 pushrods and measured with a micrometer.
ZachW04Stang is offline
69Volunteer
09-30-2015 10:39 AM
S'PortMustang69
08-30-2015 08:27 PM
hawaii5.0
04-13-2005 05:25 PM
Dan89lx
02-16-2005 09:04 PM
Quick Reply: what pushrods and rr
