pistons
RE: pistons
If you got a new block from a friend and crank and the bore is stock take your forged pistons out of your block and put them in the good block buy a berry hone and scuff and dip that puppy and paint her blue and call her new!!! if that doesn't suit you just buy a set of hyper pistons I run kieth black .200 dome hyperutectic pistons and spray them they work great for the money!!
RE: pistons
kieth blacks use different skirt clearance than pretty much everyone else and they have weird ring locations. i have heard alot of people say they have trouble with em. they may have fixed their problems, but the federal mogul/trw/sealed power stuff is tried and true
RE: pistons
Never I repeat never go with the cheap way, the first thing I remember learning from a guy when rebuilding motors was, buy the best stuff you can't afford, cause your going to abuse it! I buy the the better parts when price is an issue, so Forged or Hyper? Forged hands down, cost 20 % more but worth every penny! Or be cheap, run slow, and pay again later for better parts.Just my 2 cents worth.
RE: pistons
Maybe early on they did but alot of it was due to people not reading the instructions on piston ring installation most people just installed a standard set of rings and slapped them together which would cause the top ring land top break off you have to run a wider gap on the top ring then the lower since I built my motor for the juice that was never an issue since I custom file fit all my rings wider so as to be able to spray it. I've never had a problem with them and it's been three years with 58 cc heads it's 11.1 compression and let me tell you this sucker hauls A**! But there are certainly better choices out there. At the time these were fairly new so I thought I 'd try them If I roasted them no expensive loss paid 230.00 however to my suprise they still are going strong
RE: pistons
20% more? if i could have gotten forged flattops for 120 bucks i would have been on that like stink on sh*t. and for the record, going cheap is getting cast pistons - which is what ford, chevy, and dodge used for like 75 years without problems, so stepping up to the hyper's is a move in the right direction. are they the best? no. but if you know what your application is going to be they can be a great bang for the buck item.
uberstang1
09-20-2015 06:42 PM
