Broke a damn rolloer rocker pedestal
Starting cranking on her on wasn't running right, after compression check showed none in #2I pulled the valve cover to find out I put the rocker on wrong. I didn't know it had a round and a flat spot for the bolt. It got turned 180 on me and broke the pedestal. Only one got installed wrong. I hope I can buy just this piece.
RE: Broke a damn rolloer rocker pedestal
I depends on who makes the roller rocker?? you'll have to call the manufactorer line crane cams direct, or comp cams ect..ect.ect....... I know you can buy ford racing roller rockers through summit as a pair that's the only way you can usually get the parts as I trashed 2 roller tips on mine and they wouldn't sell just the bearings had to buy a pair of roller rockers for 60.00 dollars and they came with the pedastals
no it was intial start and I noticed it than removed it so nothing went flying. I just bought a set from mustangs unlimited, hope they work. They look the same
good luck with mustangs unlimited they would not help me a bit when I bought my new haesdlights, one broke in like 3 weeks and they told me I had to buy a whole new set.
69MustangCoupe393cid
10-03-2015 10:33 AM
