NeEd HeLp!!!!
Old Jul 25, 2007 | 06:01 PM
QbonStang95GT's Avatar
QbonStang95GT
Default NeEd HeLp!!!!
i was wondern if anybody could help me figure this out i have a 95gt 5speed and once in awhile when i drive it when i push the clutch in to shift the rpm's stay where there at at about 2-2500 rpm's ..does anybody know what this could be? thanks alot
Old Jul 25, 2007 | 06:16 PM
945LSTANG's Avatar
945LSTANG
Default RE: NeEd HeLp!!!!
i dont see what the problem is.
Old Jul 25, 2007 | 06:20 PM
QbonStang95GT
the rpms get stuck or sumthin at 2-2500 rpms once in a while and it will stay stuck untill a tap the gas pedal
Old Jul 25, 2007 | 07:05 PM
mattdel's Avatar
mattdel
is the clutch fully disengaging? can you shift gears while the motor is still revving that high?
Old Jul 25, 2007 | 07:16 PM
QbonStang95GT
yea i can and i think its fully disengaged i prety sure it is
Old Jul 25, 2007 | 07:56 PM
1985stang's Avatar
1985stang
Hm, so the engine is staying the same rpm when you push in the clutch? That sounds like the throttle is sticking if you ask me, because you said it goes back down when you rev it a little.
Old Jul 25, 2007 | 08:00 PM
QbonStang95GT
yeah it only does it once in a while, if its mi tb stickin how could i fix that?
Old Jul 25, 2007 | 08:02 PM
mattdel's Avatar
mattdel
take the throttle cable off of the throttle body, and figure out which one is sticking. both of them should move pretty freely with just your hand.
Old Jul 25, 2007 | 08:03 PM
QbonStang95GT
is it hard to do?
Old Jul 25, 2007 | 08:04 PM
1985stang's Avatar
1985stang
I'd try cleaning off the cable and throttle body with carb cleaner.
