heads, gt 40 or p heads
Old 07-29-2007, 03:49 PM
  #21
my77stang
my77stang's Avatar
Default RE: heads, gt 40 or p heads
i agree with the wife
seriously though, some of you guys are so chocked full of the crap you hear on here every day that you forget you can make power with ford heads.
in 1969 the 351w had 290 hp with a VERY mild flat tappet cam, a cast iron intake, and exhuast manifolds. the P heads flow better than the GT40's, which flow better than the 69 351w heads. now...... tell me why the GT40p's will choke a 351w?
again, yes aftermarket heads will make more power, but the heads in question will not be choking a 351w with what his current goals are.
that 1000.00 can buy all sorts of other goodies for the motor or chassis to help him finish the project.
my77stang is offline
Old 07-29-2007, 03:55 PM
  #22
danltr450
danltr450's Avatar
my77stang, my wife thanks you. she was thinking no one wanted to talk to her. she is pretty involved.
danltr450 is offline
Old 07-29-2007, 03:58 PM
  #23
danltr450
danltr450's Avatar
of I can remember right the stock heads have 124cc inake ports and the gt40's have 160cc or 154cc?
Old 07-29-2007, 04:24 PM
  #24
my77stang
my77stang's Avatar
i dont remember, but i can tell you that my 302 had 69 351w heads that had bowl porting done by a serdi and some exhaust port work done by hand. well......... that motor ran like an absolute raped ape until the day i essploded the bottom into 37 pieces.
Old 07-29-2007, 04:26 PM
  #25
danltr450
danltr450's Avatar
I am looking forward to gettting it running
Old 07-29-2007, 04:27 PM
  #26
ZachW04Stang
ZachW04Stang's Avatar
I think you may have to drill the head bolt openings too so you can bolt them onto a 351. They may make a head stud that allows you to use 302 heads on a 351 though.
ZachW04Stang is offline
Old 07-29-2007, 04:41 PM
  #27
danltr450
danltr450's Avatar
The head bolts have been drilled to a 1/2" hole for the lrger bolt size.
Old 07-29-2007, 04:52 PM
  #28
my77stang
my77stang's Avatar
then your golden
*edit*
may i suggest:
Crane Rocker Arm Conversion Kit
and
Crane Roller Rockers
Old 07-29-2007, 05:00 PM
  #29
w8less
w8less's Avatar
if your just trynig to get the car on the road then the gt40 or p whatever you got will work but for optimal potential i would get aftermarket. around a 200c head.
w8less is offline
Old 07-29-2007, 05:04 PM
  #30
w8less
w8less's Avatar
ORIGINAL: my77stang
was that addressed towards me?
also the gt40 heads would make that a torquey motor
also if the gt40 heads will not choke a 351 why was i told over and over again and then again my some very knowledgable people that my old completely reworked e7's was choking my 347? i bet my old e7's was flowing more than gt40's in question
i believe the expression that was told to me "you can't polish a turd"
w8less is offline
Quick Reply: heads, gt 40 or p heads
