Need Front brakes. What
slotted rotors will wear out faster but give you less brake fade as your brakes heat up. I doubt those alone would do much for your stopping ability. If it were me I would just do stock, unless your a road racer.
Yeagood padswould work way better than slotted rotors, but hey if youve got the money then do both! At any rate, Bendix semi-metallic are good all around brakes you can get at most auto parts stores, or some good performance ones from a magazine or something.
I would use the stock ones and get a z rated set of brakes and get a 73mm caliper will help out a ton
I bought a set of these brakes @ auto zone for 45.00 their a step up from carbon metalics. I think the 73mm would help alot there found on lincolns<edited><editID>vfast</editID><editDate>37874.887349537</editDate></edited>
Ghost_Conscience
09-23-2015 02:17 PM
maestro1024
09-21-2015 02:40 PM
