might have a problem with the diff
Old 08-05-2007, 10:41 AM
crocop
crocop's Avatar
Default might have a problem with the diff
i took my 88 stang to a mr.lube so i can get some tranny fluid for the T%. they guy opened it up to drain it and he said it was almost empty, i just started driving it so its not a big problem, when i drove out of the place i could tell the shifts were better and smoother.
the problem is the rear diff. the diff whines at the back so i thought that it might be empty to, the guy put very little fluid in it and started dripping out. he then showed me the fill cap , and there was metal shavings on it, does this mean my gears arnt set right, and there shaving off, or is it just normal wear that should be cleaned out? cars got 205 000 km on it but i dont know when the gears were put in.
crocop is offline
Old 08-05-2007, 08:24 PM
crocop
crocop's Avatar
Default RE: might have a problem with the diff
anyone?
crocop is offline
Old 08-05-2007, 08:27 PM
mattdel
mattdel's Avatar
how much metal was on the plug? there is always a little bit.
if it was normal, the fluid is good & full, i'd say u need a rebuild.
mattdel is offline
Old 08-05-2007, 08:34 PM
crocop
crocop's Avatar
hmm. well when i went to change the engine oil it was literally black, (changed no problems there). if the same applies to the rear end that could cause it so wear out then right?
crocop is offline
Old 08-05-2007, 08:35 PM
red95gtconvert
red95gtconvert's Avatar
Where is it leaking out from?, it sounds like to me like your pinion seal or cover gasket could have went south.
red95gtconvert is offline
mattdel
mattdel's Avatar
yah the fluid should definately not be black.
if its black, change it, immediately.
mattdel is offline
Old 08-05-2007, 08:40 PM
93 LX FiveO
93 LX FiveO's Avatar
my diff hums but the gears are good and t-loc works fine. i have a pinion seal leak and i think it causes some kind of noise.
my fluid looked like crap. when i changed fluid the noise didnt go away but i felt better knowing there was fresh oil in there. i found some metal shavings too but just on the plug, like matt said its fine.
93 LX FiveO is offline
Old 08-05-2007, 08:42 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
could have a carrier or pinion bearing going out....that'll put metal in the fluid too....one of my carrier bearings took a dump about a year ago and it was growling/whinning a little
mjr46 is offline
Old 08-05-2007, 08:58 PM
crocop
crocop's Avatar
i doubt its a bearing. when i drive i can clearly hear gears spinning, it whines, but i was talking to my dad and he said when he had a 5.0 it did the same crap so.
crocop is offline
Old 08-05-2007, 08:59 PM
mattdel
mattdel's Avatar
you sure that its the rear end?
if the car is a 5spd, the trans might be whining.
mattdel is offline
Seanam
10-04-2015 10:15 AM
67LimeCoupe
09-30-2015 04:46 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
09-01-2015 08:16 PM
Quick Reply: might have a problem with the diff
