5.0 build-up
5.0 build-up
Here the scenario:</P>
I'm building up a 5.0 to have 450+ HP and 500+ Torque.</P>
Twin turbos or a massive supercharger would be used, no nitro. I can't decide which one, turbos pull real hard but supers launch real hard.<IMG src=smileys/smiley5.gif border="0"></P>
I DON'T WANT to run jet fuel. I've done this and its very expensive when you drive everywhere. Premium is perfect.</P>
I don't know much about these engines. I want to know more. (pros vs cons)</P>
What is a safe bore/stroke? Where should I go for parts? (summit, jegs, etc.)</P>
What is the strongest trans and what would be the best gears?</P>
Which rear end can handle the punishment?</P>
Sorry for asking so much but 1 long post is better than many little ones.</P>
THANXZ IN ADVANCE FOR ALL THE INPUT!!!</P>
</P>
5.0 build-up
450hp would be pretty easy with a set of good heads, cam, intake, exhaust and a supercharger without using serious boost. The stock forged pistons would be fine for the buildup. The only 5sp tranny choice would be a TKO tremmec, as for an auto, C4 or AOD would both be fine, but the aod would cost more to fix / modify but would have overdrive. A stock 8.8 rear end with 31 spline axles and c-clip eliminators would work fine too. With the right planning running 93 octane and getting those numbers wont be too difficult.
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
