coolant in my oil :( :(
ok so, i just did a 347 stroker and had a intake vacume leak so i changed the intake gaskets and it was leaking coolant from the ends. So i shut it off and let it cool, and start it up again, and no more leaks.
Then i checked my oil, and its white and milky. So im thinking head gasket, but everything is new. And plus i have 125-130 compression all around. And no white smoke. So it must be the intake gasket.
So i changed it again today and my oil. Go drive it for about a mile and the car overheats. I have no coolant and my oil level is way way overfull.
So im leaking coolant into the oil but not outside.
Can it still be the intake?
BTw when i had the vac leak i used cork end gaskets. Well now im using the blue rubber ones. And thats the only thing that changed So is it the blue rubber gaskets?[/align]
RE: coolant in my oil :( :(
If your running ok and there is no white smoke from water vaporizing in the cylinders I would say yes there is a good possibility it is leaking around the intake into the rocker valley still. If you are talking about the 2 gaskets at the front and back of the motor they should have nothing to do with the coolant passages.
Fel Pro makes some good intake gaskets that come with a blue sealant bead in it, you don't have to add RTV to the coolant ports, it seals right the first time, provided you do it right
