Starting Issues Still
Old Aug 12, 2007 | 10:14 AM
88 Saleen's Avatar
88 Saleen
Default Starting Issues Still
i'm still having starting issues and its really geting old. i have an 88lx and it starts fine when the engine is cold then when i take it to go get gas or just out for a rip around, when I SHUT IT OFF it will make one crank and then jsut click.it acts like a dead battery but its not.it has a brand new battery in it and a new starter relay. if i just keep cranking to try to get it to spin over a black ground wire goin to my battery will get real hot. i am lost and slowly goin f*cking insane lol, so any adivce will be greatly appreciated. its kinda embarassing to have to push my car and pop start it everywheres.
[/align]
Old Aug 12, 2007 | 10:30 AM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
Default RE: Starting Issues Still
Well if its fine when its cold, and sucks when it heats up, then it sounds like heat soak on the starter. Do you still have the OEM ginormous starter on there?
Old Aug 12, 2007 | 12:30 PM
raven_ghostwolf's Avatar
raven_ghostwolf
ORIGINAL: WhiteFoxGT
I agree with the dark side of the force sounds like a old or weak starter getting hot.
Old Aug 12, 2007 | 12:53 PM
89 fox's Avatar
89 fox
upgrade to the 92-95 5.0 starter and rewire the starter
Old Aug 12, 2007 | 04:25 PM
88 Saleen's Avatar
88 Saleen
[/align]thanks to everyone for the replies ill try it hopefully it works cuz its really gettn annoying not being able to shut my car off to get friggin gas.
Old Aug 12, 2007 | 04:34 PM
WhiteFoxGT's Avatar
WhiteFoxGT
Resident Ford Troll
ORIGINAL: 89 fox
+1
My 93 GT had a mini starter on it. Never had a problem with starting while hot and it also is WAY easier to take off/put on.
Old Aug 12, 2007 | 04:41 PM
cobrastang88's Avatar
cobrastang88
u dont have enough ground through ur whole system, either add more grounds or go to bigger ground and positive cables
Old Aug 12, 2007 | 08:06 PM
creekrat's Avatar
creekrat
Also could be timing. Where do you have your timing set?
djbigskrilla
Sep 20, 2022 01:04 AM
mstahoo
SVT Forums
Aug 19, 2021 09:15 PM
drfister
May 3, 2018 10:38 PM
5.0 kevo
Sep 3, 2015 06:24 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
