fuel rails
RE: fuel rails
No special tool needed, just undue the 4 bolts (2 on each side im pretty sure) and carefully wiggle up pry up on the rail. Its one assembly so try to take them off evenly. Also, when you get it out then injectors might stay in the intake or they might come up with the rail. Look over the O-rings for damage and if they are still good, lube them up real well before you go to install the rails. If not you WILL ruin them and leak fuel everywhere.
RE: fuel rails
ORIGINAL: primetime5.0
uhh there is a special tool need to separate the fuel rail... you cant rent them from auto zone
here is a different version than the ones you can rent..
mrappe
09-26-2015 10:16 AM
