I have a miss
I have a miss
i have a miss in my 91 gt and i have done a complete tune up on it ( plugs,wires, cap, rotor and fuel filter) and that helped a little bit but it still feels like it has a miss to it. does anyone know wat this could be?
RE: I have a miss
If you have a miss at idle but none at higher cruising rpm's I would suspect a vaccum leak....you can check all vaccum hoses and or a possible egr valve partially stuck open due to carbon build up on the pintle but using carb cleaner spray all vaccum hoses and intake gasket mounting areas and listen for change in rpm's that'll indicate a leak
Matt's 95 Stang
10-05-2015 07:16 AM
breaking
10-02-2015 01:27 PM
