AOD transmission
AOD transmission
Is there any way to control second gear manually with a diff shifter or an upgrade to the transmission? shifter has 1,D and overdrive. if im in D is there and way to be in second without it shifting into 3? why didnt they just have 1,2,D, and overdrive on the shifter? I would rather have a manual for daily driving but is there anything i can do. I know i could by a shifter with 1,2,D. and overdrive but that just wont work will it. What about an electric button on the shifter that some cars have that turns overdrive on/off.
I want second! Thx
I want second! Thx
RE: AOD transmission
well at the track when you at WOT have it on 1 when you take off, when you want to go to second, shift the lever into D. after it shifts into second, throw the shifter back into 1 and that will cause it to hold 2nd. when your ready for 3 just shift it back into D again.
or you can get a manual valve body and a different shifter
this method will work but will play havoic on your OD/3 bands. do this to many times and youll lose OD then 3rd. so be careful. best bet would be a shift kit that sets teh shift points higher or say a valve body like lentech where it has 123 and OD is electronic
ORIGINAL: ohsoquik02
Thx for the info i looked at the lentech website and understand it now just have to decide. I may just go with the shift kit. But the the B&M 4 speed shifter and the valve body from lentech also look good.
aod, automatics, button, electric, lentech, od, sale, shifter, transmission, transmissions, upgrades
