rear end removal
rear end removal
i just replace my U joints and also discovered that my break line....ruptured which is yet to be fixed. but while i was down there i noticed the original paint down there is flaking and looks pretty terrible along with other dirt and grime......if i removed my suspension and rear end cleaned everything, painted, would the reinstall of the rear end just bolt in? is there allignment issues? is it possible to get things out of allignment? also when i do this i can upgrade as i put it back together such as upper and lower control arms and removal of quads and i can sand and paint my rusty rear end.
RE: rear end removal
ORIGINAL: FASTBLACK
Yes to all of that. I have dropped many rear ends, though the last one was over a year. I dont think it is possible to bolt it up wrong.
sweet! hey you wouldnt happen to know for sure. are the break lines standard or metric? i bought a standard break line flaring tool with line bender.i assume standard since my chilton book says 3/16" break lines. but also in fine print on the picture is says 8mm right by the 3/16" but then again that doesnt make sense either.
ORIGINAL: CCF5000
Im curious about this also if its possible to pull the rear end out and put a new one in yourself or is it too dangerous and better left to two ppl?
