How do you "Pull Codes"....
Old Aug 22, 2007 | 02:13 PM
blahman20's Avatar
blahman20
Default How do you "Pull Codes"....
I'm having an idle problem....sometimes it will just start idling at 1800 by itself, then a few minutes later it will come back down when I stop again. I think it's MOSTLY happening when the engine is already warmed up, but it happens at different times. I know it can be a few things...IAC, TPS etc....however I was just curious how do I pull codes? Do I need the Code reader thing (lol)....and any ideas on my problem?
Also today when I was driving it started to shake a bit, like it was missing, and the rpm's were going up and down!! then 2mins later I took it around the block and it idles good and didn't shake at all....weird.
Also on cold starts...it idles then falls then idles then falls then idles then falls then eventually it will stay at around 900....until it gets more warmed up and it starts to idle way up again.
Old Aug 22, 2007 | 02:30 PM
Hawk's Avatar
Hawk
Default RE: How do you "Pull Codes"....
http://www.muscularmustangs.com/test1.php
That should do it for you.
Old Aug 22, 2007 | 03:02 PM
TwotoneVert's Avatar
TwotoneVert
Thats a good link, thanks Hawk.
Old Aug 22, 2007 | 03:04 PM
Hawk's Avatar
Hawk
Not a problem.
Old Aug 22, 2007 | 03:06 PM
blahman20's Avatar
blahman20
that makes no sense to me but thanks anyways.
Old Aug 22, 2007 | 03:29 PM
Joel5.0's Avatar
Joel5.0
You may also want to check DIY KOEO/KOER self-tests ......
Old Aug 22, 2007 | 06:51 PM
Hawk's Avatar
Hawk
ORIGINAL: blahman20
If that doesn't make sense than you might want to consider purchasing a code scanner for like $30 at your local parts store.
Urambo Tauro
Oct 5, 2015 09:37 PM
Mr. D
Oct 1, 2015 01:03 PM
microgt
Aug 20, 2015 07:12 AM
Casper98GT
Feb 20, 2005 12:30 AM
